Slitting a brass saw back
Discussion in 'Saw Makers Forum' started by ray, Sep 20, 2008.
  2. pedder
    pedder Guest
    Hi Ray,
    nice looking gauge. I wonder how to use it. If used with a saw file wouldn\'t it be destroyed? Do you stick something on the site of the file wich touches the gouge?
    Cheers Pedder
    Edit: sorry, wrong thread.:S
  3. kevjed
    kevjed Guest
    Thanks Ray. This looks like a very practical way of doing it. I would guess that your drill press table is raised and lowered for course adjustment and you shim the timber jig for fine? Thanks for the insight.
    Kevin
    Hi Kevin,
    A bit of additional info, the bottom of the arbor that holds the blade is resting lightly on the
    wooden block, (drilled out with a forstner bit to the right depth. The idea here is that I don\'t want the saw to drop out of the morse taper, if it does, I don\'t want it to go anywhere.
    A drill press is not really designed for side loads, so the hole helps take up some of the side load as well.
    The next version, I will put a bearing under it, and the drill chuck is only tightened late in the setup.
    One other thing, I cranked the drill press down as slow as it would go, and backed off the belt tension
    so in the event of a jammed blade it just spins.
    I plan to do a more detailed write-up, maybe make a full article for the website.
  5. mranum
    mranum New Member
    Where can you get a blade and mandrel like that? I haven\'t seen them before. I thought about the abrasive cutting wheel but I think they would get too hot.
    Hi mranum,
    I got mine off ebay (that\'s the el-cheapo way), since I\'m only slitting brass I went with the cheap option.
    Here is the arbor
    http://cgi.ebay.com.au/SLITTING-SAW-SLOTTING-SAW-HOLDER-WITH-1-2-SHANK-NEW_W0QQitemZ380110696282QQcmdZViewItemQQptZAU_BnI_Woodworking_Metalworking?hash=item380110696282&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A1|39%3A1|240%3A1318
    if that link is too long try..
    http://tinyurl.com/d383rk
    and do a search for \"slitting saw\" you should find whatever blade thickness you need.
    A better quality selection of slitting saws and arbors from a good engineering supply house like,
    http://www.victornet.com/cgi-bin/victor/productlist.html?subdepartments=Saws,+Plain+Slitting:658,661
    or shorter version... http://tinyurl.com/ctv7ah
  7. mranum
    mranum New Member
    Once you have the back slit, how do you mount the blade? Epoxy, pin, or press the assembly together, any of the above?
    I would assume a press fit or epoxy would be the best choice cosmetically for the final finish.
    Hi mranum,
    I just clamp the slit brass in the vise with cauls either side and squash the 20thou slot
    a little to provide an interference fit.
    You can use a little bit of loctite as well if you want. Not necessary in my experience.
  9. regisand
    regisand Guest
  10. rtleach
    rtleach Member
    I got an 1/2 arbor and slit blade from McMaster and mounted it in my router table. Turned the speed way down and made a sled to hold the brass (and save my fingers). I make about 3 passes to slit the 1\" brass bar stock. Works like a charm. I\'ll post pics in a day or so.
    Robert
  11. Mike Allen
    Mike Allen Member
    I'm considering the same and would love to see your pictures.
