Filing a saw with progressive rake is a difficult task, the front angle of the tooth is different for every tooth on the blade. The idea of this set up is to provide a continuous visual indication of the angle so that as you work across the saw the string tells you how the file should be angled. The pictures of the set up are here... http://www.backsaw.net/cpg/thumbnails.php?album=21 Regards Ray
