Grinding a saw blade
Discussion in 'Saw Makers Forum' started by fredd3039, Oct 31, 2013.
  1. fredd3039
    fredd3039 New Member
    I have seen it on some of the how to's that portions of a saw should be taper ground. Does anyone have any info on how this is done????? Or could you point me in the proper direction?
  3. fredd3039
    Tapering the blade
    Thanks for the info. I was looking for a tutorial on taper grinding it. I understand the concept but what techniques and how the process is done is what I am really after. I have a surface grinder but I am curios as to how they are grinding on it.
    I'm travelling a similar path, I've got a surface grinder but have never ground any saw plate, I guess it's about time to give it a try.
    Here's japansese Nakaya saw blade grinder.
    http://www.nakaya-saw.com/en/machine_taper.htm
    I did find a picture of the surface grinder that flinn garlick use to taper grind their hand saws, but it doesn't really tell me much, other than that it's a very wide wheel?
    I'll let you know how the grinding goes.
    PS that picture is from facebook https://www.facebook.com/WorkshopHeaven/photos_stream
  5. pmcgee
    pmcgee Most Valued Member
    Old school grinding was on the BIG grindstones ... with the blank held in a wooden 'sabot' for want of a better word.
    "Disston uses large stone wheels to taper grind there saws. When the stones became worn down they were used to build bulk heads on the Delaware river."
    http://positiverake.com/?m=201207
    There is a picture from the Hawley Collection http://www.hawleytoolcollection.com/index.php?sheffield-tool=audio-visual
    It is for knives ... but I'm sure I have seen the same thing happening with saws ... half an idea it was about the Disston works. :confused:
    The japanese are still doing it ... for knives at least ...
    http://www.youtube.com/watch?v=RKx4ZaRCsKc (1min)
    http://www.youtube.com/watch?v=aU6u80Hyw5Y (1min)
    http://www.youtube.com/watch?v=K0BtDfJCNL8 (9min)
  6. pmcgee
